Originally Posted by sleepydo
what about emission inspection? i can see if it obd1 then it would be sniff test but obd II read everything.
Alabama = No Emission Testing
I could run a 2G eclipse ECU that is OBDII and it would test ok if I ever move out of this state , but that's not happening.
BTW I logged a 2nd gear pull without the LM-A cable. Before the turbo spools it is running about 13.7:1 and slopes to 11.5:1 @7000rpm. I have Thursday off to tune the car. The plan is to install the manual boost controller and try running 16psi after adding more fuel. I have to find some way to mount my new camera. Trying to shift and hold a camera isn't working. Especially when it wants to get a little loose into second @ 65+mph.
