Re: IC pump replacement
Not sure by those pictures,but are you sure you're not confusing the auxiliary heat pump for the ic pump? There's a pdf.file with pictures in post#2 of this thread that should help you. If you remove the splash shield under the car that covers the motor you'll see the ic pump right near the radiator on the passengers side.
https://www.crossfireforum.org/forum...oler-pump.html
