Old Nov 14, 2011 | 05:26 PM
James1549
Default Re: Hello to you all...Please help if possible
If I'm understanding your post correctly, you may start with having your battery checked - charged and load tested. Once that the battery is confirmed good, I would check for a bad RCM. If those two things check out fine, then you will have to get a better diagnoses.
Good luck, James
