Old Nov 15, 2011 | 09:46 AM
onehundred80
Default Re: Hello to you all...Please help if possible
Originally Posted by britishcommando
Ok ive done the RCM and it still hasnt solved the problem so its obviously something else.
I reconnected the battery and turned it over. It fire up and after 3 secs died.
I started it again and it lasted about 2 secs.
Started once more then start and die.
Now wont start
If i disconnect and reconnect it starts the process again.
All the electrics come on and the spoiller pops up
So confused??!@@
Do you have a spare key? If so, try to start it with the spare.
The chip inside the Fob may be damaged.
Have you been under the dash? As the halo wires may be disconnected or broken.
The car thinks you are trying to steal it and the immobilizer is kicking in.
This is a security problem, the dealer may be your only hope I'm afraid. It pains me to say that.
