Re: Crossfire brake pedal is not firm and slips down toward floor
Don't see any fluid around master cylinder. Same issue as someone else had. Changed front pads, and have very soft pedal. Have bled the fronts twice. Will change out the rears and rebleed all four wheels starting at the rt rear. Watching for leaks at calipers. See some had problem with seals after compressing the caliper piston. Did not open bleeder when compressing caliper.
From what I read hear: could have air in system, compromised seal on caliper, pushed garbage into the ABS, bad master cylinder.
