Old Nov 30, 2011 | 07:18 PM
  #42 (permalink)
MrMoPar's Avatar
MrMoPar
Default Re: Morimoto HID Kit Install & Review Thread. Pics and Lots of Reading!
Okay, now I really like the Morimoto, but was leaning heavy toward one from Euro Effects. Anyone have any experience with them? They seem to make a high end kit. Close to same price, would like to see info on the Morimoto fog conversion before I decide.
What makes the EFX Conversion kit beat the competition
The common fuse is often replaced by resistors, relays, or modules. However, newer vehicles 2006 and up are now using computer controlled modules for headlights. Due to the update, relays, resistors, & even some fuses are now being eliminated. EFX Euro Effects has specially programmed our digital chips inside our ballast to function with OEM standards; thus giving you no errors, no flickering and no DTC codes. We have designed size specific plug-in type connectors to connect to OEM power cable without any cutting, which makes it a simple Plug-and-Play installation. When it comes to putting an aftermarket HID lighting kit on your car, buying some cheap generic HID kit is not the way to go. Why take the risk of burning up your $2000 computer, damaging your Headlight system , or even your housing and wiring costing $600 or more? We at Euro Effects don't play a guessing game when it comes to designing our ballast for your vehicle. We went through 1000's of hours of testing and programming making sure our kits work with all vehicle manufacturers. Our HID bulbs were designed to meet OEM standards like Philips and Osram quality, but at an affordable price for all to enjoy. We strongly believe our color rendering is amongst the best in the industry. We have the widest selection of Kelvin and Exotic colors. Our bulb's life is 5000 hours and can easily withstand harsh conditions. The EFX HID bulb colors are very rich and guaranteed not to fade or burnout.
WHY OUR BALLASTS ARE CONSIDERED THE BEST QUALITY
The most advanced HID ballasts made in China use a CPU programming controller (Digital Ballast). The program is so easy to copy that an electrical engineer could easily make this type of ballast in his living-room. This is why HID makers in China have grown so rapidly. These types of ballasts are not capable of real-time lamp monitoring (lamp current always changing). The operation is not smooth and safe, and then it causes many problems from electrical damage to possible fire loss. Many of our customers have already tried these so called "Super Digital Ballasts", and many customers always say that an HID system that is made in China is no good, and their one year warranty is difficult. Color Fades, Lights flicker, colors wont match. These are all very common problems with cheap HID.
ASIC EuroEffects ballasts are equipped with an ASIC chipset controller which, is the same type as HELLA (BMW, Mercedes HID Manufacturer); Matsushida (Nissan HID Manufacturer), etc. This type of chipset is very difficult to design, and cost our Engineering Department $600,000 to develop. This chipset has the capabilities of real-time lamp-monitoring and protection. EuroEffects chipset stabilizes the unit for perfect function at all times in all conditions. This crucial point is why our HID ballasts can last up to 10,000 Hours without any problems. HID bulb life is 5,000 hours using our ballast, compared to only 2,000 hours using CPU controller found in China ballasts. EuroEffects HID systems can be put in a class of quality that very few companies can reach.
EFX hid kit BENEFITS
  • Standard Kelvin colors reproduce the color spectrum of daylight almost exactly
  • 3x the improved visibility at night & bad weather
  • Great choice for people suffering from bad night vision
  • Reflects road markings and signs better than any conventional halogen lights
  • Enables drivers to concentrate better on the roads, less eye fatigue & much safer driving
  • Increases reaction time due to better visibility with its added contrast to the road
  • 3600 Lumens means super bright output compared to standard Xenon replacements or stock halogen bulbs
  • 35% less power consumption than your stock halogen bulbs (More Eco Friendly/Green)
  • Directly replace all OEM/stock HID bulbs of domestic & imported vehicles
  • Makes your car look unique, adds style, & luxury
  • Simple & quick, Plug & Play Installation
  • Extra long life expectancy: Over 5000 hours of bulb life compared to original halogen bulbs 200-300 hours.
  • This kit can last the entire life or your vehicle once installed.
  • Works 100% without any interference to the Newer BMW, Lexus, and Mercedes computers.
  • NO RELAYS OR ERROR cancellers needed
  • E-Mark , TUV ISO 9001-2000 certified
  • Lifetime limited warranty.
Professional equipment
Every HID conversion kit EuroEffects produces is put through a 12 stage testing process before it ever leaves the factory. EuroEffects spent 1.2 Million dollars just in Quality Control testing equipment. Most companies selling HID kits don't even have a Quality Control Department and if they do they simply test the product to see if it turns on. EuroEffects is setting the standard in QUALITY HID lighting and they back their HID kits with the best warranty in the business.
