Old Nov 30, 2011 | 11:31 PM
MrMoPar's Avatar
MrMoPar
www.TheCrossfireShop.com
Default Re: No off idle throttle response (barely moves)
Originally Posted by Infinity
Have seen the same issue and can actually get it to replicate it while in park and when cold so I know its not the pump again (replaced already). All I can figure wout so far is that it has something to do with the virtual kick down switch, either it is bad or there is some sort of interrupt in communication on the can-bus with the TPS
I assume that switch is in the gas pedal assembly?
