HID Kit help please
I had a hid kit running successfully for 6 months, then a bulb went, i stupidly left the engine running when i was fiddling with the cables and there was sparks and the right handside bulb would no longer work, not even a standard bulb, I had to take it to a garage who replaced a blown fuse...
I've fitted the left handside hid kit fine and it works, but for some reason the righthandside doesn't work on HID, but works for a standard bulb, I've tried changing the known good bulb and ballast that works on the left handside to no avail... I've come to the conclusion that i need a new bit where the bulb plugs into as there is a bit of plastic missing on the side, that was cracked... so I think the standard bulb works fine as the metal pins are very rebust and make a connection, whereas the hid kit pins are a bit more flimsey and aren't making a good connection with the bulb housing.
To be clear I'm talking about the lead circled in GREEN as per pic...
Anyone have any sugguestions? or know where I can get a replacement lead circled in green?
As at the moment I have one HID light and another standard light, it looks crappy!
