There will be no need for additonal tuning. I would highly suggest having the stock tune before installing the kit. Tuning involves keeping the air fuel ratio correct and and keeping the MAF sensor in check. This has been factored into the kit price. I highly doubt the elbow from the MAF sensor to the throttle body will still be on the car after kit installation. I believe the charge pipe will be similar to a Needswings intake and eliminate the elbow.
So this is going to be an install and forget it type kit then??? So no need for a boost controller or wide band gauge/contoller??? So the psi will be set and no adjustments will need to be made to fine tune??? Good in the aspect that its one size fits all and tuning can be a pain in th a$$. Bad that it makes it limited. But I believe in Corky and know the product will deliver. And I'm sure the power and powerband will be great for our car. Only worry is Just from past experience, tuning for a turbo added car was different between a manual and a autostick auto... But not familiar with our car ecu, so not sure on that.
