Old Dec 15, 2011 | 04:00 PM
  #160 (permalink)
frankeyser's Avatar
frankeyser
Default Re: BEGi Crossfire Turbo Kit by Bell Experimental Group
Originally Posted by crosseduphwy101
So this is going to be an install and forget it type kit then??? So no need for a boost controller or wide band gauge/contoller??? So the psi will be set and no adjustments will need to be made to fine tune??? Good in the aspect that its one size fits all and tuning can be a pain in th a$$. Bad that it makes it limited. But I believe in Corky and know the product will deliver. And I'm sure the power and powerband will be great for our car. Only worry is Just from past experience, tuning for a turbo added car was different between a manual and a autostick auto... But not familiar with our car ecu, so not sure on that.
from what I understand, the boost model is being borrowed from the Kleeman supercharger that was used on both manuals and autosticks. It will be a set amount of boost and the extra fuel adjustments will be what is changed.
I do believe we are going to have boost gauges but I am not sure. Also there will be the possibility of a stage 2 turbo using an srt6 ecu. Rotrex I think is his screen name has recently had some success controlling boost levels with an srt6 ecu.
