Old Dec 17, 2011 | 11:09 AM
oledoc2u
Default Re: Now an xf owner couple of issues need help with?
Originally Posted by doggboy
To be honest I really haven't a clue, is it easy to revert to standard lighting format if it makes the mot a problem.
Since its belting it down with rain here it has also developed a water leak I believe from where the boot joins the top of the car, could be where the cabling goes in & rubbish has perished?.
Steering seems better now I sorted out tyre pressures, I can't work out how to turn on/off the airbag to eliminate the error light.....any clues?...what does it look like?
you cannot turn off the air bag light. For what ever reason, someone had the air bag out and messed with it which caused the "light" to come on. It has shut down your air bag system. Only an authorized dealer with the "star" system can reset it. Been there done that when I had a door skin replaced.
