Old Nov 17, 2005 | 03:41 PM
  #41 (permalink)
respdoc's Avatar
respdoc
Default Re: Super charger questions
Originally Posted by Bob G
Black SRT
Kleemans supercharger is a bolt on with 7 lbs boast and gives you 330 hp with-out their chip which makes it 350 hp.
Close...but not quite. The 7 lb "Low Boost" kit produces only 280 hp by itself. To get around 330 hp you will either have to go with the higher-boost original kompressor Kleemann offers or add to larger fuel injectors and intercooler to the low boost kit to make those numbers...
Roadster,
Good luck but since it looks like you just bought the car be prepared for quite a bit of down time with the vehicle along with having to work thru quite a few "bumps" out...Can it be done?...Sure, but just be prepared to what your going yourself into.
I've worked on a some late-model domestics, japanese and in the recent past; M.B.'s and can say the benz's are the most challenging just based on the computers control and bi-polar mood that they seem to display when doing mods.
