Originally Posted by radmanly
Thanks for the reply. When you say I don't need to upgrade injectors or plugs, do you mean I don't need to do that to get the most from the CAI or that I don't need to bother at all because the stock injectors and plugs are just fine?
Would it be fair to say that biggest "bang for the buck" mods are, in order, CAI, tune, exhaust? Once those are done, would I see incremental power improvements from injectors and plugs or none at all?
Injectors are more so you do not lean out on your top end. If you do them you will have to get a retune on a dyno to make sure they can map them all out for you. I think it is like 1-2 hours on the dyno.
