Old Dec 22, 2011 | 06:08 PM
32krazy!'s Avatar
32krazy!
Default Re: Installed a 2nd heat exchanger today.
Originally Posted by velociabstract
If I finally decide to change the I/C pump I'll use what the big dogs use. (Meziere WP136) You know what, I think my PTE thermostat is sticking. Were having a cold snap and coasting down the mountain my ECT's dropped to 160º. That shouldn't happen. It leads me to believe it may not be opening all the way either.
Les
my pte tstat died this spring. replaced with the oem . les cmon 10 hp by sealing the ends with insulation? no way! i used pipe insulation to keep my supercooler from rubbing on the rad. most only use the meziere if they have a trunk tank and need to push the fluid forward to the cm30
