Old Dec 22, 2011 | 06:13 PM
velociabstract's Avatar
velociabstract
Default Re: Installed a 2nd heat exchanger today.
Originally Posted by 32krazy!
my pte tstat died this spring. replaced with the oem . les cmon 10 hp by sealing the ends with insulation? no way! i used pipe insulation to keep my supercooler from rubbing on the rad. most only use the meziere if they have a trunk tank and need to push the fluid forward to the cm30
I'll let you know.
Les
