Originally Posted by Adrian_X
You lost me with that one lol
So the fuel pump actually builds pressure at the on position? I thought it kicked in right when you start the engine. Should I try turning the key to on, wait a bit, THEN start?
Ah.. I think we've drilled to the nerve of the problem
.. I always turn my ignition to "on".. let it sit a couple seconds..you can hear the fuel pump building pressure (spooling up if you will)..then roll over to the crank position. Now if that is the problem.. don't just go cruising.. get back with us here.. lol.
