Old Dec 31, 2011 | 06:29 PM
SparkieSRT6's Avatar
SparkieSRT6
SSB SRT6 405hp/401Tq
Default Re: Window Switch Drivers side
Jim,
If your car is an automatic:
You can use the smooth side of a credit card or plastic wedge to gently pry up on the narrow silver border (shifter bezel ring which is about 1/2" wide by 3" by 5" rectangular piece). It is held in by four tabs (two on each end) be sure to lift straight up. You may/may not need to remove the slotted shifter gate cover but if you do it also lifts straight upward the same way. Now you can lift up the coverpiece that has the window switches mounted in it. You should be able to easily remount the window switch as it snaps/clips back into position from below.
