Old Jan 2, 2012 | 11:44 AM
Mrmiata's Avatar
Mrmiata
Default Re: Running wires for aftermarket amp and rear speakers ('05 Base)
Great job on the video! Wish I would have found this when I decided to put my amplified bazooka tube in. Researched enough and found enough pictures to comfortably take on the project. I ended up feeding a clothes hanger from the inside of the rubber grommet to use as a wire pull to keep from having to take the battery out. Still running the stock HU so I tapped into the input side of the amp for my speaker leads and tapped the remote turn on into the ignition on power lead there too (no extra bass when parked on acc..and less chance of killing the battery by extended play time). It came with a "craddle" and straps for mounting and I used velcro on them to hold it to the carpet. Figured anything more than that to hold it was going to be the least of my problems
