Old Jan 3, 2012 | 04:10 AM
  #41 (permalink)
Reliableron's Avatar
Reliableron
Default Re: Car Alarm Keeps going off!!! Dead Battery!?!
Thanks GraphiteGhost! there is an electrical connection on the cowl cover but the washer hose can be moved out of the way with the cover. There are two clips that hold wires in the front center of the cover which need to be removed like you stated. I did not remove the battery cable but might be a good idea - I wasnt thinking but once you disconnect it you could throw it in the neighbours pool if it is going off....
