Or one might take the more logical approach (and I know 32Krazy..not on your car)...
Variation Bolt AKA Wobble Bolt Bolt for PCD Variation
Hex17 M12 x 1.25 x 29.5
With this new item you can use one wheel with unified center bore for several applications. This bolt is fitted with a mobile conical washer which keeps the bolt axis perpendicular to the car flange while allowing radial displacement and a consequent PCD variation.
Set of 16 - $64.00 Set of 20 - $80.00
Hub Adapters and Spacers
