Old Jan 4, 2012 | 08:54 PM
Mrmiata's Avatar
Mrmiata
Default Re: Locking wheel nut remover?
Gator Grip Universal Socket Kit
Everything you need in the palm of your hand
Maybe you've seen the "Gator Grip" on TV and you wondered if it really did all they claimed. I can tell you it does! This one socket fits all nuts and bolts from 1/4" to 3/4" and all metric sizes from 9mm to 17mm. And it fits odd shapes like wing nuts and eye bolts too. The trick of the Gator Grip is that the socket is made up of 52 spring loaded steel roller pins that automatically conform to the shape of the nut, bolt or whatever you want to tighten. And here's the best part: I've combined it with a flexible stubby ratchet and a belt pouch so that you have an entire lightweight socket set that fits in the palm of your hand and you can carry it on your belt. It also comes with an adapter that lets you to use the socket with your electric screwdriver. When I show the Gator Grip in person--everybody wants one. This is the coolest new tool I've seen in a long time.
#69505 Gator Grip Kit $59.95Quantity:
No self respecting wheel thief leaves home without one!.. Also available at most local pawn shops for a song-dance and $3.50 (at least mine was)
