Originally Posted by bobs
If you really get stuck you can pull the entire headlight assembly out, but that involves removing the front tires to get at the bolts underneath.
Not really - if you remove the front sidelights, you can see the outside bottom bolt for the headlight. Then all you have to do is turn the wheel all the way left/right, remove the little door, and use a 1/4" 10mm on a 6" extension to remove that bolt. The inside bolt can be accessed inside the hood with a 10mm open end and your fingers.
Here's a hint I may have mentioned in another post : after removing all 4 mounting bolts, the plugin wiring harness and the running light, if you then remove the 2 hollow adjustment things on each side of the headlight bottom, you can remove it from the car much easier, as it provides more clearance.
Upon re-installation, get the light assembly in, then start the two adjusters in the threads. Mount the headlight with the top 2 bolts first, then hand adjust the adjusters until they just touch the mounting tabs, secure with the 2 bottom bolts.
