I am swapping my custom drive-shaft I built during my swap to a standard one piece U-joint shaft. You could use the adapter plate or yokes found here and eliminate the flex discs completely.
FYI- mercedes drive shaft adapter
Update!!! These will not work!!!! The center bore is correct but the bolt hole circles are wrong
