re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
I did mine a few months ago and it now works better than new...its not as hard to do as it looks. Took me two hours. If the ket wont turn at all, you have to drill the pin on the steering column to get the assembly out, it takes fifteen minutes or so...i used a dremel. Once you drill that pin, the arm and assembly will slide to the right and pull out at an angle...this was the only step that was not clear to me in the tutorial...good luck.
