Old Jan 16, 2012 | 01:53 PM
TomStratRT's Avatar
TomStratRT
Default Re: Installed Super Bright LED Daytime Running Lights
Originally Posted by KelloggKid
I purchased a set of these LED's from one of the ebay sellers in the OP. When they arrived I noticed that the protective strip had seperated from the adhesive in several places. I suspect the adhesive then dried out. At any rate, less than a week after I installed them they are starting to come loose. I cleaned the headlight housing very carefully and used rubbing alcohol as well. They looked really great but I don't think they'll stay on much longer.
Funny you should say that, I had the same problem. I ripped them off and will try again when it gets warm outside. I think the missing ingredient is heat and I'm not going to fight with old man winter using a heat gun to put these things on.
