Old Jan 16, 2012 | 07:32 PM
SparkieSRT6's Avatar
SparkieSRT6
SSB SRT6 405hp/401Tq
Default Re: Installed Super Bright LED Daytime Running Lights
Originally Posted by TomStratRT
Funny you should say that, I had the same problem. I ripped them off and will try again when it gets warm outside. I think the missing ingredient is heat and I'm not going to fight with old man winter using a heat gun to put these things on.
You're bang on. I layed mine flat across a forced air heat register in the house and ran the furnace for 15 minutes to make them more plyable for going around the tights corners. I took them out to the garage for installation one at a time when ready to install. Mine stuck really well and have not moved. When installing the LED strips, I was very careful not to touch the adhesive side of the strips and only peeled a little of the paper backing at a time.
I guess I should have mentioned this and will add this to the instructions.
