Old Jan 19, 2012 | 09:02 PM
onehundred80
Default Re: Installing Rear Camber arms
Originally Posted by turbomar
The OEM links are 11.3/4" centers. You can start by setting the adjustable links to 12" centers. The OEM links curve around the sway bar. The straight ones come awfull close but if you lower the car by 1" or less, it will be fine. The fact that it is straight makes it much stronger and rigid.
I know about the strength, I'm not lowering but is a lowered car closer or farther away from the sway bar?
Did you get the diodes?
