Old Jan 20, 2012 | 10:21 PM
maxcichon's Avatar
maxcichon
Default Re: Installing Rear Camber arms
Dave, I don't think you could rotate an adjustable bent arm 180° without it hitting the sway bar during rotation. But then I don't see it a problem to disconnect one end to get the proper length for a good alignment.
James
I think Dave is envisioning a bend only to offset the materials own thickness. Maybe 5 degrees or so. You would be stuck with a one-turn adjustment modulus, or, in my case 2 X 1/18" per turn. One thread module per end per turn. Full turns only.
