Thread: Rear wheel help
Old Jan 25, 2012 | 05:05 PM
MetalMilitiaSRT's Avatar
MetalMilitiaSRT
Default Re: Rear wheel help
The higher offset will move the wheel more under you car. As MikeR said, your biggest concern will be suspension and brake clearance. This however can be corrected with a spacer; a 10 mm may be enough. (You'll need to get new, longer lug bolts though) As long as you maintain the overall height of the wheel/tire combo, the 20" size won't really matter. (Bigger wheel with a lower aspect ratio tire) Remember, less tire = more road feel. Personally, I don't mind. Some do.
PS: Find a new wheel/tire shop. This kind of situation is rather common.
