Rear wheel help
Old Jan 24, 2012 | 11:15 PM
roadstermiketx's Avatar
Default Rear wheel help
This is a simple question, but I can't seem to find the answer in the masses of threads on the site. I am also pressed for time since I already ordered the rims and need to confirm that they will fit. The guy told me they would and then sent me a random email saying they won't so I am highly confused and need help. The front are no problem and are already ordered but the rear that I am looking at are 20" x 8" with a high positive offset. The tire is the same size as stock, but what I am concerned about is if this new rim will fit, he says it won't and I need a medium offset not a wider rim. I have looked at a good amount of literature and it seems like it would fit to me because of the high offset but the skinnier rim could cause a problem so I need help.
Old Jan 25, 2012 | 01:38 AM
MikeR's Avatar
Default Re: Rear wheel help
not enough info.... what is the offset of the 20x8 rim???
Old Jan 25, 2012 | 02:33 AM
not to sure, it doesn't specify online do I'd have to call tomorrow and check, but correct me if I'm wrong, wouldn't going with a medium offset like the salesman told me be worse than a positive because it would leave less room for suspension etc...and when I get the extra rim info I'll post it!! thanks for the help
Old Jan 25, 2012 | 01:42 PM
it is a 40 mm offset on the 20 x 8
Old Jan 25, 2012 | 04:28 PM
MikeR's Avatar
Since your stock rear wheel has a offset of 22 you will be 18mm/0.7" closer to the rear suspension. You are also 1" taller in overall height....
Try this tool for comparing wheels and tire sizes....
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Old Jan 25, 2012 | 05:05 PM
MetalMilitiaSRT's Avatar
The higher offset will move the wheel more under you car. As MikeR said, your biggest concern will be suspension and brake clearance. This however can be corrected with a spacer; a 10 mm may be enough. (You'll need to get new, longer lug bolts though) As long as you maintain the overall height of the wheel/tire combo, the 20" size won't really matter. (Bigger wheel with a lower aspect ratio tire) Remember, less tire = more road feel. Personally, I don't mind. Some do.
PS: Find a new wheel/tire shop. This kind of situation is rather common.
PNA
Nov 12, 2020 04:44 PM
MAXIMUM
Aug 4, 2015 11:04 PM
tom2112
Jul 28, 2015 08:12 AM
ardenian
Jul 27, 2015 04:41 PM
Buchacho
Jul 9, 2015 04:13 PM
