Originally Posted by andrew
both fuses are fine.
i am now wondering about the "brown ground wire" i disconnected under the drivers seat to eliminate the annoying seat belt chime...has a shared circuit with the seat heater?
can anyone research this? thanks in advance.
Andrew, you may have something there. Remember, the fuses are on the "hot" side of the circuit. After current passes through the heater it has to return to ground somewhere. You should look around to see if there is another ground wire for the heater, or just reconnect the ground and see if the heat works.
