Old Jan 31, 2012 | 12:25 PM
JHM2K's Avatar
JHM2K
Default Re: stock Crossfire vs v8 Crossfire
Originally Posted by Bigkid
John the rears are pilot super sport 285 30 ZR 20.
What time difference would you speculate this set up would add vrs the 17" dr's ?
Your setup is nearly an inch taller than OEM... And, quite a bit heavier to boot.
Ignore the rim width/backspacing, as I just put something in there to fill the void...
This gives you a visual reference of how much taller the wheels/tires are. To alleviate this with a 20" wheel, you'd have to drop to a 25-series tire... not worth the risk of bent rims and zero cushion IMO...
