stock Crossfire vs v8 Crossfire
Old Feb 2, 2012 | 10:52 AM
Default Re: stock Crossfire vs v8 Crossfire
Originally Posted by FUBU
Nice! I would like you to do 10's what speed do you get with street tires?
sorry i don't use street tires when i am at the track but my mtstreets are 10.50 x 26 x16 that makes thenm the same height as street tires,, yet they do grow to about 27" over 100 mph.
Old Feb 2, 2012 | 12:16 PM
Bigkid's Avatar
Originally Posted by JHM2K
Absolutely.
Can you tell me what your rear tire specs are? A thinner sidewall would certainly made the OD smaller, yielding an effectively lower gear (or in your case, closer to stock).
Problem is, the thinner the sidewall, the less sidewall flex you have and therefore the easier it is to break traction for a launch. The 20's are killing you, but they sure do look pretty. Even the factory 19's on our cars are torque-stealing boat anchors. There's a reason Les is running 18's all-around...
John I am planing on attending a couple of Hooked on Driving events this year as well as the Crossfire event in NC. I have been putting this set together for a while and picked up the 18" all around ADR wheels with Toyo R888 dedicated track tires set yesterday. We put them on the car to check fitment and then I drove it over to the twisties to check them out.
I could really feel the difference in accelleration over the 19/ 20"s. I had no idea it could make that much difference. The fronts are 225/40ZR/18 and weigh 40 lbs( bathroom scales) and the rears are 295/30/18 and weigh 48 lbs. No rubbing and a lot of fun. Probably did not get them heated up good so the best is yet to come.
I am sure there are much lighter wheels out there but I got this set up in my budget with the main focus of saving the wear and tear on the pilot super sports.
BTW I have a set of Hoosier P275/40R/17 drag radials that I have had for a while and yet to try. LOL.
Old Feb 2, 2012 | 05:16 PM
32krazy!'s Avatar
just bring the hoosiers to me jim ill let you know how they hook!
Old Feb 2, 2012 | 07:57 PM
what a limited running in the 11's,,, # 6 same as before # 7 went a little sideways on take off.
Old Feb 2, 2012 | 08:02 PM
Bigkid's Avatar
Not a problem Steve. Any thing for one of my car buds. I wish you guys from the "boro" could come to the GTG Dyno day in Spartanburg on Saturday but I understand it is a long drive.
Old Feb 2, 2012 | 08:10 PM
32krazy!'s Avatar
im heading to cullman al. to swap dr's with black srt6 so i can leave my big brakes on the back. and my tcu is in houstoin for retuning on the tcu mod. big manis going on everything is thermalcoated gold to match the calipers.
if your not busy on feb 11 theres a open house at buckhead imports in smyrna ga. bunches of m/b and bmw going to be there. stop by!
Old Feb 2, 2012 | 08:12 PM
Bigkid's Avatar
Can't fool me, I would know the sound of that car any where. I have been behind it enough lately. Nice pass!
Old Feb 8, 2012 | 02:21 PM
Bigkid's Avatar
Originally Posted by 32krazy!
big kid is far from stock. more like he's the needswings catalog and then some! jim your run @ 111 leads me to believe your running lean at the top. with the 12.3 you should be @ the 114 to 116 range. check your dataloggs please. my guess is the car is losing power at the top of 3 with the ecu pulling timing. if you still have the same tune you had when we met in atl its way past time for a retune!
Well I finally found time to datalog and you guys were absolutly correct. Lean on the top begining around 5k rpm. Rob has the info and we will be adding fuel at 5k using the Needswings fuel management system.
thanks Steve, Grip Grip, Jim, Mimi and all who caught this and commented.
Old Feb 8, 2012 | 02:52 PM
vpats's Avatar
Hummmm, I wonder if he'd pick up a few MPHs if he turned off the air conditioner?
Old Feb 8, 2012 | 03:10 PM
JHM2K's Avatar
Should be a beast once dialed in, Jim!
Old Feb 8, 2012 | 05:32 PM
Bigkid's Avatar
Air conditioner on the track absolutly taboo! Outside air conditioning .
Old Feb 8, 2012 | 07:39 PM
32krazy!'s Avatar
hope to see you sat jim. you will be one of the first to see the new drag pack! hopefully i wont have any issues. so many things going on at once my reliabilty seems to be suffering. i need to get some miles on the car
KDW4Him
Jul 10, 2015 12:04 PM
SRT SIX
Jun 22, 2015 05:37 PM
MJPowers
Jun 8, 2015 02:34 AM
catch36
Aug 19, 2003 03:21 PM
tlb44
Aug 17, 2003 05:45 PM
