Old Feb 8, 2012 | 09:44 AM
JHM2K's Avatar
JHM2K
Default Re: Instrument Cluster
Originally Posted by mrobinso
+1. I have heard taking apart the dash in the Crossfire is extremely difficult. TimeZLord would be a good member to contact. He posted a DIY on changing the console led lights to obtain a different color and was planning to move on to the odometer cluster next - don't believe he has gotten to it yet.
I've disassembled the dash roughly four times, and it's no picnic. It's also no like rebuilding a transmission, either. I can definitely tell you some shortcuts... Biggest thing is KEEP UP WITH THE SCREWS. Twice, I reassembled the dash only to have a screw (yes, one) leftover and for the life of me, I swore everything was buttoned up properly. On the following disassembly, I found it. So, label them if you must... whatever keeps them straight. Work slowly, methodically, and don't be scared to bend a little plastic... the shroud around the instrument cluster is a b!tch to remove.
bhalbeck -- I will swing by Steve's tonight to check the cluster's clear plastic. I'm pretty sure it's the one from my spare set of Crossfire/AMG gauges, and the plastic was in outstanding shape. But, I also had two clusters floating around at one point so I'll definitely need to double check that for ya
