Instrument Cluster
Old Jan 29, 2012 | 09:15 AM
bhahlbeck's Avatar
Default Instrument Cluster
Mine is good but the plastic is less than perfect. Any idea if I can transfer one from another SRT 6 with ease? Will my odometer read the same? What's an approximate cost for a used one in good condition? Let the warm temps bring on the interior work!
Old Jan 29, 2012 | 02:45 PM
JHM2K's Avatar
Default Re: Instrument Cluster
Are you describing just the clear plastic face plate?
Old Jan 29, 2012 | 09:16 PM
bhahlbeck's Avatar
Exactly that.
Old Feb 1, 2012 | 04:22 PM
JHM2K's Avatar
I may have a spare, let me check with Steve.
Old Feb 6, 2012 | 11:59 PM
bhahlbeck's Avatar
That would be amazing, assuming a shell swap is possible. It would actually be perma-grin material. I'm willing to pay too.
Old Feb 7, 2012 | 12:30 AM
JHM2K's Avatar
It's definitely a separate piece. Problem is, you must disassemble EVERYTHING to get it swapped.
Oh, and I'm glad you bumped this because I completely forgot about this. I'll ask Steve tomorrow
Old Feb 7, 2012 | 05:19 PM
bhahlbeck's Avatar
Thanks John. I'll wait to hear back.
Old Feb 8, 2012 | 09:20 AM
beasticles's Avatar
+1. I have heard taking apart the dash in the Crossfire is extremely difficult. TimeZLord would be a good member to contact. He posted a DIY on changing the console led lights to obtain a different color and was planning to move on to the odometer cluster next - don't believe he has gotten to it yet.
Old Feb 8, 2012 | 09:44 AM
JHM2K's Avatar
I've disassembled the dash roughly four times, and it's no picnic. It's also no like rebuilding a transmission, either. I can definitely tell you some shortcuts... Biggest thing is KEEP UP WITH THE SCREWS. Twice, I reassembled the dash only to have a screw (yes, one) leftover and for the life of me, I swore everything was buttoned up properly. On the following disassembly, I found it. So, label them if you must... whatever keeps them straight. Work slowly, methodically, and don't be scared to bend a little plastic... the shroud around the instrument cluster is a b!tch to remove.
bhalbeck -- I will swing by Steve's tonight to check the cluster's clear plastic. I'm pretty sure it's the one from my spare set of Crossfire/AMG gauges, and the plastic was in outstanding shape. But, I also had two clusters floating around at one point so I'll definitely need to double check that for ya
Old Feb 8, 2012 | 01:20 PM
waldig's Avatar
Talking Re: Instrument Cluster
Have you considered having the plastic polished?????? Thats what I would do first and maybe second. Woody
Old Feb 8, 2012 | 01:29 PM
JHM2K's Avatar
Good call!
He could probably use the headlight restoration kit with great success...
Old Feb 9, 2012 | 01:04 AM
bhahlbeck's Avatar
I'll take a pic of my issue and post it soon.
Old Feb 9, 2012 | 10:06 AM
JHM2K's Avatar
If it's cracked or gouged, you'll definitely need a replacement. If it's only marred/lightly scratched, the headlight restoration kit ($30) should work perfectly.
Old Feb 12, 2012 | 03:54 AM
bhahlbeck's Avatar
Used my 3M one. It's perfect now. Got the dash tear down badge too! Thanks for the grey idea.
Old Feb 12, 2012 | 11:48 PM
JHM2K's Avatar
Awesome!!! I'm stoked for you man, you're like me, can't look at an imperfection and simply leave it there, lol
Old Feb 13, 2012 | 10:34 PM
bhahlbeck's Avatar
I must have been tired looking at my grammar. It was a 3 hour job from start to finish, but it looks like it rolled off the assembly line now. Great idea once again. I'm getting my console touched up next.
Old Feb 9, 2020 | 12:39 AM
Fildo Dog's Avatar
Can any of you gents tell me the bulb spec for the 2 watt and the 1.5 watt instrument cluster bulbage?
Fildo Dog
sanfoor
16
Dec 23, 2013 06:42 PM
NDLanoue
Jul 10, 2008 05:12 PM
cgocifer
Oct 6, 2007 06:06 PM
John Webster
Mar 2, 2005 12:05 AM
andrew
Mar 29, 2004 06:18 PM
