Old Dec 2, 2005 | 12:08 AM
respdoc's Avatar
respdoc
Default Re: Hyper Voltage System
Originally Posted by Cyril Baldwin
Actually if you check out www.greenfilters.com they already use the same principle incorporated with their $300 twister green filter for crossfires.
If you have high - end home theater system, hyper voltage system is the same principle as the Monster Cable Voltage regulator and high - end gold cables. They make the sound much more cleaner and crispier and the colors much better than regular cables. With a 1000 watts subs in my trunk, although I have a separate battery for my audio system, I bet it still takes off some power in my crossfire.
Visit me at: http://www.cardomain.com/ride/2053478
While Green makes some nice drop in filters that still would not explain why OEM manf. have not adopted this technology if part of the solution to greater MPG's is that simple.
While gold connectors help to minimize signal degradation and help to ensure a corrosion-free connection point; significant corrosion buildup issues on a new car's electrical system should not be an issue. If it is, a simple 10 min. clean-up job would save you the $230 bucks and give you the same results.
I hope you understand that the extra weight and load the second battery and subs puts on your car negates any gains these "hyperwires" could ever hope of achieving...
