Hyper Voltage System
Old May 14, 2006 | 09:46 PM
  #61 (permalink)
trobertson7's Avatar
Default Re: Hyper Voltage System
Originally Posted by danimal
If you READ the article, it is all explained to you why...you don't even have to guess.
Thanks...yes, I read the comment that the 850R was an automatic so they couldn't hold a single gear and had to use higher engine speeds to maintain 3rd gear.
But their table states...
RPM - Hp Before - Hp After - Gain - Torque Before - Torque After - Gain
5,200 189.3 192.2 2.9 191.2 193.0 0.8
5,300 188.9 194.9 6.0 187.1 192.1 5.0
But when you look at the data from the graph, at 5,250 rpm the blue lines appear to show that the non-modified HP and torque values are greater than the red HyperVoltage lines.
I was looking for an explanation as to why the performance changes versus engine speed, and why the data table doesn't agree with the dyno graph. I guess I should have been clearer.
Old May 15, 2006 | 07:22 AM
  #62 (permalink)
danimal's Avatar
I see what you are talking about and I can't explain it either. Like I said earlier...I did not install it for those particular claims, but it definitely works as far as the other claims go. Whether it increases HP or torque and at what RPMs, I will leave to others. But I can attest through experience with this thing, that the voltage & RPM fluctuations are GONE. I'm satisfied with the purchase and you are satisfied that you didn't...so it's all good.
TerryR
Dec 13, 2019 03:27 PM
blackpepper
Oct 4, 2017 06:09 AM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
caseydeankopp
Sep 13, 2015 07:25 PM
