Old Feb 17, 2012 | 05:56 PM
lildaddym's Avatar
lildaddym
Default Re: New to the gang...
Originally Posted by alaxfire
1. the valve cover oil leak : yes very common, but easily remedied ( lots of threads on that )
2. the top not going down :
do you hear the pump trying to run ? if not, then most likely the stupid little switch that the trunk divider actuates.
If you DO hear the pump running, then you have $$$$$$$ problems.
( when I bought mine, the dealer didn't know about the little trunk sensor switch, I got an EXTRA $2000 off his price when I informed him what a top replacement costs. - I also got another $500 off due to the valve cover oil leak )
Ok, as long as that's easily remedied, not going to concern myself with that.
I don't hear the pump running...I figured that it might be a switch. Is there a way to get the top down manually? Where is that switch you're referring to.
I did get $1,000 off when I mentioned those items...the car was originally priced at $10,850...got it down to $9,995...
