Old Feb 19, 2012 | 07:05 PM
Javier Busquets's Avatar
Javier Busquets
Default Re: I am screwed... (Sound system)
Originally Posted by Musclefan21
Well, I JUST found out that the previous owner not only replaced the stock headunit, he also replaced door and rear speakers. Which is supposed to be a good thing but I am not satisfied with the sound that much.
door speakers are Crunch GTR and rear speakers are PYLE brand. Not sure about their size or any other specs. All I know is I am not really satisfied with them. Must sound better than stock since he "upgraded".
I just bid on a stock infinity radio from a 2007 crossfire and I am thinking about picking a pair of Infinity kappa speakers (no idea which size so i will need your help. a link would be greatly appreciated.)
About rear speakers, I want to put something more powerful but I do not want to upgrade the stock AMP. So something powerful enough for stock AMP.
Also, the rear speakers are facing inwards, hard to explain, i will post pics very soon. Basically driver side rear speaker is looking at passenger side and pass. side rear speaker is looking at diver side about 45 degrees. Is this normal or this dude modified it?
The thing that bothers me the most is, my door handles are professionally covered. Whoever did it, did one hell of a job, looks like from the factory. And the problem is, in order to replace the speakers, i need to remove the door panels and in order to replace the door panels, i need to remove two screws from the door handles which i have no access
I don't know what to do at this point, where to start, etc...
First of all what he did was place the factory woofers base backwards, maybe one of the only and easy ways to replace those two sub woofers and use a voice speaker. Take into consideration that the factory amp only offers low bass sound to the rear channels so you have to use another amp to work this out, I'm facing the same problem with mine.
