Old Feb 20, 2012 | 12:34 PM
syfi's Avatar
syfi
Default Re: good buy on battery
Been extremely happy with my Shuriken BT20. Only 14 lbs. and can be had for less than half the cost of the Deka.
SHURiKEN 12-Volt Car Audio Power Cell features a sealed absorbed glass mat (AGM) design and is perfect for 600-watt car audio sound systems. The SK-BT20 can be used as a replacement for your vehicles standard battery or as an additional battery to provide the extra power needed for a high performance aftermarket system. It's unique spill free design allow this power cell to fit in most factory battery locations with no hazardous leaks.
SHURiKEN's SK-BT20 Power Cell puts out 850 cranking amps with a 20 amp hour rating. This battery will resist extreme heat conditions and vibrations and is 100% sealed in a reinforced ABS plastic case. SHURiKEN has designed this power cell to be used with ring terminals or a buss bar. You will love the way SHURiKEN batteries get your system powered up and ready to go!
Battery Features
12V High Performance AGM Car Battery
For use with audio systems up to 600 watts
Engineered specifically to meet the needs of a high end audio system
Using AGM (Absorbed Glass Matt) technology allows the battery to be mounted in any position
Unique spill free design
Extreme heat resistance
Resistant to heavy vibrations
Super low ESR
Packed closely with pure lead plates
100% Sealed and maintenance free
Designed to be used with ring terminals or a buss bar
SAE Posts available: Shuriken SK-SAE20
Wing Nuts with Posts available: Shuriken SK-WN120
Authorized Internet Dealer
1-year Manufacturer's warranty
Battery Specifications
Amp Hours: 20
Cranking Amps: 850
Weight: 14 lbs.
Dimensions: 3"D x 7-1/2"W x 6-1/2"H
$65 @ SonicElectronix.com
http://www.sonicelectronix.com/item_...SearchClickout[query_id]=6584945&SearchClickout[Ignore]=1#tabs
