good buy on battery
Old Feb 4, 2012 | 08:14 AM
Default good buy on battery
Seems to be a good buy for an AGM 48 series battery at Tri State Battery Online Catalog
( free shipping )
My roadster had the previous version DEKA battery when I bought it, I have had NO issues, and this one is the newer technology Absorbed Glass Mat battery.
9AGM48
[9AGM48] $169.95
Click to enlarge
AGM European Performance Battery
9AGM48 - AGM Battery
The Deka AGM Performance battery will fit many European & Domestic vehicles including: Audi, BMW, Chrysler, Jaguar, Mercedes Benz, Mini, Porsche, Saab, Volkswagen, Volvo and many other vehicle makes!
  • Meets OEM AGM requirements for exact fit replacement
  • Electrolyte absorbed by micro-porous glass separators eliminates acid spills and terminal corrosion
  • Tightly "packed" construction and calcium reinforced grids provide greater resistance to shock and vibration
  • Provides plenty of starting power at lower temperatures
  • True maintenance-free performance means longer life with hassle-free service
  • Superb dual purpose design delivers excellent starting and accessory power
  • High porous separators lowers resistance and increases power
Specifications:
  • Cranking Amps 875
  • Cold Cranking Amps 760
  • Ah Rate (20 Hr) 70
  • Group Size 48/91
Dimensions:
  • Length 11"
  • Width 6 15/16"
  • Height 7 1/2"
Old Feb 20, 2012 | 12:34 PM
syfi's Avatar
Default Re: good buy on battery
Been extremely happy with my Shuriken BT20. Only 14 lbs. and can be had for less than half the cost of the Deka.
SHURiKEN 12-Volt Car Audio Power Cell features a sealed absorbed glass mat (AGM) design and is perfect for 600-watt car audio sound systems. The SK-BT20 can be used as a replacement for your vehicles standard battery or as an additional battery to provide the extra power needed for a high performance aftermarket system. It's unique spill free design allow this power cell to fit in most factory battery locations with no hazardous leaks.
SHURiKEN's SK-BT20 Power Cell puts out 850 cranking amps with a 20 amp hour rating. This battery will resist extreme heat conditions and vibrations and is 100% sealed in a reinforced ABS plastic case. SHURiKEN has designed this power cell to be used with ring terminals or a buss bar. You will love the way SHURiKEN batteries get your system powered up and ready to go!
Battery Features
12V High Performance AGM Car Battery
For use with audio systems up to 600 watts
Engineered specifically to meet the needs of a high end audio system
Using AGM (Absorbed Glass Matt) technology allows the battery to be mounted in any position
Unique spill free design
Extreme heat resistance
Resistant to heavy vibrations
Super low ESR
Packed closely with pure lead plates
100% Sealed and maintenance free
Designed to be used with ring terminals or a buss bar
SAE Posts available: Shuriken SK-SAE20
Wing Nuts with Posts available: Shuriken SK-WN120
Authorized Internet Dealer
1-year Manufacturer's warranty
Battery Specifications
Amp Hours: 20
Cranking Amps: 850
Weight: 14 lbs.
Dimensions: 3"D x 7-1/2"W x 6-1/2"H
$65 @ SonicElectronix.com
http://www.sonicelectronix.com/item_...SearchClickout[query_id]=6584945&SearchClickout[Ignore]=1#tabs
Old Feb 20, 2012 | 12:38 PM
OK in Florida, not so reliable in the frozen north. Not enough storage capacity, weight = power.
Old Feb 20, 2012 | 03:24 PM
coolx's Avatar
I still have an oem battery, not sure how old it is, I bought the car in late September and I've been concerned about needing one. When I saw your post I was curious so I clicked on the link, found the battery for $64.99 - free shipping. So, what's the catch? How long have you had your battery? It's just at that price, it seems too good to be true...
Well I found the battery at Amazon and according to the description, it's to power an audio system...not what I intended to use it for
Old Feb 20, 2012 | 04:24 PM
It's intended for racing - less weight
Old Feb 20, 2012 | 05:55 PM
syfi's Avatar
Needswings sells the same battery as a kit to fit the Xfires. It includes the SAE top post adapters and a custom made battery tie down spacer for around $90, which is very reasonable. I went this route looking to cut weight on the popular belief that every pound shed gains you 1 HP. My car is my daily driver back & forth to work, so it works fine for me. Had it installed since last Nov. and not a lick of problems. There are a few other members who use the same setup.
http://www.needswings.com/Shuriken-L...-bt20-kit.aspx
Another cool thing being done is mounting the battery behind the passenger seat, freeing up the battery tray area for NOX or intercooler installs.
Old Feb 20, 2012 | 06:31 PM
Try this deal I got for my truck ( https://www.crossfireforum.org/forum...0cca-sale.html ), it (the coupon code) may still work. $35.00 is quite a discount!
Old Feb 20, 2012 | 06:40 PM
I have the shurikyns in both cars...but keep them maintained... life support so to speak...they won't last as long as a regular battery, but they sure do cut down on the weight...and leave room for other things...
jgreen
106
Sep 18, 2017 11:46 PM
crossfiren00b
U.K.
Aug 18, 2015 01:58 PM
axnguyen
Jul 21, 2015 11:41 AM
cx24724
Jul 12, 2015 11:57 AM
FIXRE
Jul 9, 2015 09:16 PM
