Question to owners who upgraded speakers on n/a limited
I am considering switching front speakers and tweeters on an 04 limited for Alpine SPR-17c and Jl tweeters and was told id need a separate amp for them. Did anybody who upgraded their speakers use stock amp? I believe its about 250 watt... Or have any suggestions for an amp in case I would need one? Also I have 10" Alpine R in the trunk on a 1000w Kenwood Monoblock D amp bypassing stock amp for now if that matters.
Each channel produces 22 watt rms.
The subwoofers in the rear get 4 x 22 watt rms. The subs are double coil speakers.
The front system gets 22 watt rms.
The stock amp has an simple integrated processor. If you want to replace it you have to mention that.
If you use the alpine / jl speakers with a passive crossover there is no need for an additional amp.
If you want to run the system full active and if you have a hu that supports that you can use use the internal amps of the hu to run the system full active, or use it for a bi-wiring passive x-over solution.
It's no problem to find an amp that fits in the stock place position. But the place is a little tricky itself, because there are many cables and you don't have a very good possibility to seperate chinch cables from currency and other cables. Sometimes it's not easy to get a noisefree signal (hum, or whistle from the alternator while driving).
Originally Posted by bigblock427
The stock amp is a 6 channel digital amp.
Yes, the amp has an internal crossover for the subs. So it makes no sense to use 2 subwoofer channels for 2 rear channels.
If you have an aftermarket radio with 4 channels you can use 2 of them for rear channels and level them with the fader of your radio. But i'm personally not conviced that rear vocal speakers improve the sound. The main problem is the tweeter position in the doors. It's better to use some good aftermarket tweeters and put the into the a-pillar.
Example: http://www.chrysler-crossfire-forum....nlage/#post989
Regards
Markus
Regards
Markus
KDW4Him
18
Sep 1, 2021 05:47 PM
Kodebuster
Nov 5, 2020 04:06 PM
Dave Wilson
Jul 18, 2015 05:31 PM
