Old Feb 20, 2012 | 10:11 PM
latemodel21's Avatar
latemodel21
Default Re: Paddle shifter install instructions completed
Originally Posted by turbomar
ah ha! I was wondering what the tapping into the center of the 5 wire connector was for, the drive signal. Thanks Professor Chris. Oh, btw, what are the 2 up/downshift voltages?
tks... Mario
if you are asking what the up and down voltages are in the shifter; they are both normally 5vdc (and 0vdc when activated)
if you are asking, "what are the coded-voltages between the steering column and the paddle-shifter-main-module", the answer is approx 9vdc for "DOWN" and 5vdc for "UP" (or 9/14 x vbat and 5/14 x vbat respectively).
The directions cover checking the validity of your install by measuring resistance (rather than voltage) as i think that is a better approach
"DOWN" is 3.65k ohms to ground, "UP" is 1.2k ohms to ground.
Chris
