Old Feb 21, 2012 | 12:17 PM
  #38 (permalink)
lildaddym's Avatar
lildaddym
Default Re: New to the gang...
Originally Posted by alaxfire
Timing chain, there is no recommended replacement interval.
Only things you might consider are :
1. air filters
2. oil & filter ( Mobil1 0-40 & fleece Mann filter )
3. steering stabilizer
4. brake pads ( and maybe rotors - depends on condition )
5. cabin air filter
( I replaced all the light bulbs when I got mine last year with 42k on it, but then, I'm kinda **** like that )
I can see the air filter change...I know the car tells you when it's time for an oil change, but if you change it early, can the 'timer' be reset?
What's the purpose of the steering stabilizer?
Light bulbs: Seems that there may be one that is out in the instrument panel, between the speedo and the tach...should I bother replacing it, unless I'm being OCD?
