BEGi Crossfire Turbo Kit by Bell Experimental Group
Feb 22, 2012 | 05:56 PM
340
permalink
onehundred80
Apr 2006
25,432
650
Ontario
Re: BEGi Crossfire Turbo Kit by Bell Experimental Group
Quote:
frankeyser
a couple of threads about the 6 speed they may want to look over real quick
https://www.crossfireforum.org/forum...-good-not.html
https://www.crossfireforum.org/forum...two-shift.html
Reading those posts would make you want to sell the car at once. LOL
I had a manual and it was fine, a bit notchy 1 to 2 and reverse but you get used to it and it becomes no problem. They do appear to get better with use so that's good. The clutch is fine and not a long throw as some stated, there is no need to go to floor on it and it is quite capable of delicate use, not in or out like some.
I had the car from new, an '04 and it had no problem jumping out of gear and that was solved with an adjustment when it happened anyway, see the TSB on it.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
