Originally Posted by jamesknox
Yes, I actually have found the pin. I just don't understand how to fit a 1/4" drill into that tiny space to drill out the pin. How did you hold the piece of trim back...drill the pin and slide out the assembly all at the same time??
You dont have to do all of that at the same time.
First you drill, then after you're done drilling. You remove the assembly. Not remove the assembly as you're drilling. Hope that makes sense.
