Originally Posted by rekcah
You dont have to do all of that at the same time.
First you drill, then after you're done drilling. You remove the assembly. Not remove the assembly as you're drill. Hope that makes sense.
And I drill until when? Until the pin falls out? until it disappears? until it's flat?
Does it matter if I accidently drill into the metal around the pin by mistake.
