Originally Posted by Mrmiata
Did you check the relay contacts while you were soldering the RCM?
Mrmiata, when you say check the contacts, check them for what? & how?
Got in the car to day, it turned over & started & shut right down, the second try it started up & stayed running. It will run fine with no problems, till you shut it off, & try to restart it again, then it's the same problem. Some times when i try to start it, it will have nothing, like the battery is dead, then what i have to do is disconnect the battery cable, & keep touching it on the termanal untill i get a good spark, the it will start, & keep running, like it resets a relay or something.
I'm telling you it's driving me NUTS. Any ideas ?? Thanks 4 getting back with any help. Ron.
