Eng. cut off
Old Feb 24, 2012 | 02:53 PM
MikeR's Avatar
Default Re: Eng. cut off
Your problem does sound like a RCM issue.... you should check ALL the solder joints(I re-did ALL of mine to make sure they were good).... The relay contacts can be checked by separating the spring loaded plate and looking at the contacts with good lighting... if you find any that are badly pitted and black you can clean them up some with a contact file or fine sand paper... not much room so it will take a bit of work.....
The other option is to replace the RCM.... I think they go for about $150-$200....
Old Feb 24, 2012 | 03:55 PM
Smokin Red '06's Avatar
The RCM checks out to be good
Old Feb 24, 2012 | 03:59 PM
Mrmiata's Avatar
Seems kinda odd the transponder chip would work and then start causing problems..
55chevy
Jul 22, 2024 02:31 PM
MK2005
Nov 12, 2015 11:11 AM
jaesa
Sep 7, 2015 01:50 PM
Crossfireone
23
Aug 25, 2015 04:56 AM
pioneer4x4
Jul 27, 2015 02:04 PM
