Old Feb 28, 2012 | 03:33 PM
BoilerUpXFire
Default Re: Adapter Lug Bolts To Studs?
OK, let me get this straight, they come in sets (2 each) so you would need 2 sets AND will both sets fit either hub? What would it do to the wheel, will it stick out past the fender? Will the tires rub the wheel well if you flex the suspension? I like the idea of the lug nuts, I guess you tighten the lug bolts through the spacers onto the hub, then torque to 81 ft/lbs, how much are the lugnuts torqued to? Will the wheel actually ride on that center ring (the OEM doesn't ride on a ring they just move all over until you bolt em up). So, thats about 8 questions in this query. So far so good, especially if they work, don't hit the fenders (tire) and don't stick out too far.
GG, these you are talking about are actually spacers, so yes, they are going to push the wheels out. If you want it to stay stock except to be using lug bolts instead of studs, you need to do something just like the conversion I posted above...
